what is the cost per minute over ur limit
alpine1
7 REPLIES 7
@alpine1
For Canada wide calling $0.01 per minute with the $5/500min add on.
alpine1
TKS much
geopublic
@alpine1  The cost is $0. Public is prepaid so if you go over your limit it just stops working. Your options when that occurs are:
  • Purchase an add-on
  • Change plans
  • Renew your plan early by submitting a ticket to PM.
Triguy
PM is prepaid so there are no overages.  Once you reach your limit for minutes/text or data then it stops
RossN
@alpine1  hi there is no extra cost your service just stops if you need extra minutes there is an add on for 5 dollars /500 minutes
hairbag1
ZERO...once you reach your plan limit of 100 minutes...your calling just stops. You can then get an add-on of 500 minutes for $5.
will13am
@alpine1 , Public Mobile is prepaid and as such there are no overage fees. That said it costs $5 for 500 minutes of Canada wide calling minutes.  These add-on minutes do not expire.
