08-28-2020 02:49 PM - edited 01-05-2022 03:41 PM
Hello I've been with Public Mobile since January, worked fine in late July they didn't take payment and since then no service, not sure what happened, it's like I was deleted, can anyone help?
08-28-2020 03:56 PM - edited 08-28-2020 03:57 PM
@VideoStop1 wrote:Hello I've been with Public Mobile since January, worked fine in late July they didn't take payment and since then no service, not sure what happened, it's like I was deleted, can anyone help?
@VideoStop1 Did your credit card expiry date change? If not, then the suspension was the result of a bug with Public Mobile's Auto-Pay system failing and suspending your account.
You should submit a ticket to Public Mobile ASAP asking to fix the problem and also compensate you for your loss of service.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
08-28-2020 02:54 PM
@VideoStop1 your account was probably suspended beacuse your autopay failed. Did you forget to update your credit card? Please check this and do it if required. If it isn't then you may reactivate a suspended account online or by calling 611.
Via your account online
1. If you have already registered, or will first register, a credit card, go to step 2. OR deposit a voucher for at least your plan cost and go to step 3.
2. Go to the payment tab, select single payment and amount due.
3. Select the reactivate account button.
4. Restart your phone.
or Using 611 to make your payment: ( you need your 4 digit pin to buy an add on)
1. press 1 to make payment
2. press 2 credit card ( or 1 voucher)
3. press 1 amount due.
08-28-2020 02:53 PM - edited 08-28-2020 02:53 PM
Hi @VideoStop1 ,
You have not had service since July?
If you account is suspended in your self serve account and you want it ACTIVE. Make a manual payment to cover the cost of your plan, then Resume/Reactive it on your self serve account.
After reactivating you may need to be reconnected to the Public Mobile network.
Try one or more of the below:
*rebooting your phone
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reboot your phone again
08-28-2020 02:52 PM
If you have autopay with a valid card, or paid in full, but have no service, you likely need assistance from the moderators.
To get a ticket click https://publicmobile.ca.ada.support/chat/ and enter your question into SIMon. Invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear. Click it then login and pick the topic, if needed, from the drop down menu. To confirm your ticket has been submitted, check the SENT box in your private messages; click the small envelope beside your avatar at top right on your screen.
While you're waiting check out the workarounds in this post: https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/SOLUTION-My-plan-has-enough-f...
Just in case response is very slow and the workarounds fail, engage a backup plan. Mine is using fongo.com over wifi, but I think Textnow is currently slightly better as they include SMS.
If you encounter problems submitting a ticket, you can send a private message to Moderators here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437, but this alternative method may have longer response time.
