how to contact moderator
dave2
Hello. How do I contact whichever MOD happens to be online? Is there a list somewhere?
13 REPLIES 13
@AgnesCollins
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Note your old providers account must be active to port your number.  The port will close it once its completed.  Welcome to PM.  Stay safe.
@AgnesCollins
@AgnesCollins wrote:
Thanks for reply but my account is not established as yet
@AgnesCollins ok you can activate here https://activate.publicmobile.ca/ or try the live chat to sign up https://www.publicmobile.ca/en/bc/plans
AgnesCollins
@AgnesCollins Hello If you have finished the process of signing up go into your self serve account and simply change your Sim number, Over to the right on the main page under my profile it says change the Sim card simply change Sim card number there  good luck
Once you receive your new SIM card, you can change the SIM card number on your account and reactivate your service via Self-Serve by following these steps:
  1. Log into your Self-Serve account
  2. Go to Plan and Add-ons > Change SIM card
  1. Enter your new SIM card number into the field. Your SIM card number is found on the back of your SIM card, as outlined in the image below:
AgnesCollins
When I tried to activate my account my SIM was damaged.  I have received a new SIM. How do I proceed
dave2
@adobochad
Yeah, I'm definitely leaning towards your interpretation of the situation.
All users that have chosen to show their online status are here. I think it's set to on by default anyway.
Hover over or click on the username and you can send them a pm. But I seem to think that the individual mods block incoming pm's. So as above... just send pm's to the team.
adobochad
Good luck with getting a moderator to reply to you.
I've waited 45 hours, no reply so far.
Apparently (removed) fan a couple days ago that they're trying to fix internally* so i'm guessing will take some time.
edited by computergeek541: terms of services of this website
ShawnC13
Messages go into a general mailbox that they all have access to.
To send a private message to a moderator click this link and describe your issue.
Community Moderators are available from Monday-Friday 8 am(Eastern) to 12 am(Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm(Eastern)
More info on moderators
duffer900
 @Moderator_Team < Click this.
bishamon
Hi,
In order to contact the Moderator team, I would suggest sending them a private message.
Link below:
