12-15-2019 02:38 PM - edited 01-05-2022 10:02 AM
I have activated with success and now ready too add Autopay too the second sim I activated....I wander how long it will activate
12-15-2019 05:55 PM
Bingo!
12-15-2019 04:29 PM
Setting up AutoPay means that you earn $2 every 30 days!
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
Two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info
Note: When entering the postal code do not enter any spaces. Also do not use the unit number field even if you live in an apartment or condo and use a desktop browser if you can.
Hope this helps!
12-15-2019 03:52 PM - edited 12-15-2019 03:53 PM
Here's how I understand it. But two posts here make me question this.
Using a payment card on initial activation and checking the box that says you're choosing autopay will get you an initial $2 credit and the later $2 reward.
Not checking that box will not whether using a payment card or a voucher.
Setting up autopay after activation using a payment card will get you the $2 reward for later.
I don't think vouchers can be used to set up autopay. The post from PAULRANG18 and a couple later from the OP saying it looks like that make me question the voucher part.
OP: is this what you see? No payment card but autopay set up?
12-15-2019 03:22 PM
I skipped the credit card input,I was in hurry working on road and bought at store voucher and set up some quickly.
now Sunday having some time too add autopay on my second sim, already have for other sim
12-15-2019 03:19 PM
yepp, looks that way,
12-15-2019 03:17 PM
yes I know voucher is immediately but now I can add autopay for further savings . voucher payment does not reward you, I will add it now and let thi update continue .
12-15-2019 03:10 PM
Autopay usually requires registration of a credit card but you can do it via voucher as well. Either way, you'll get the 2.00 Autopay reward.
12-15-2019 03:06 PM
@dboxtvinfo715 wrote:I have activated with success and now ready too add Autopay too the second sim I activated....I wander how long it will activate
You can only set up autopay using a payment card. If you activated using a voucher then you miss out on the free initial 2 bucks of autopay credit.
12-15-2019 02:59 PM
@dboxtvinfo715 , auto pay activation takes effect immediately.
