Reply
Unintended Payment
Hi,
I was trying to change my plan and to make a payment, but the website was so slow that I mistakenly paid for my plan two times. How do I get a refund please? I need my account balance to be $25. Thank you.
Warmly,
Ngoni
Re: Unintended Payment
YOu can keep it there, it will be used next month anyway.  Or other addon.
@Ngonidzashe, refunds are not easy to process and have long lead times.  If you intend to stay with this service, you can ask for the credit to be applied to future renewals.  You will need to ask the moderator team to process the credit or refund.  The moderator team can be reached via private message using this link.  Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
@Ngonidzashe wrote:
Hi,
Warmly,
Ngoni
I suggest leaving it there as the system draws from your account before charging you anything. So as mentioned, it will just sit there until your next renewal or you chosse to use it with an add-on.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
Moderator
Hello @Ngonidzashe
Sorry to hear about the accidental double payment, but please note that the extra payment will remain on your account, as a credit, until your next renewal.
In this case, you will not have to top up next month Smiley Happy
If this does not seem suitable to you, please send us a private message, so we can work out a solution.
Best regards,
Ashley
** Current delay is of 48 hours **
@Moderator_Team wrote:
Hello @Ngonidzashe
Best regards,
Ashley
I like that they added the delay time in the reply.
Hi,
That's okay thank you, but it would be cool if I could get a refund.
Warmly,
Ngoni
@Ngonidzashe wrote:
Hi,
Warmly,
Ngoni
If you are ok with leaving it there than that is good, but I believe what the MOD was hinting at was a refund.
