Reply
Highlighted
Switched plans for the next billing cycle, still showing the old amount
After my first few weeks with Public Mobile, I'm loving the service! I am currently on the $30 2gb plan and it's been a great fit, however I feel going forward I won't need quite that much data every month.
I found the change plan tab in thesthe account serve and was pleased to see you can set your plan change for the day of your renewal (2 weeks from now) however, in my account overview it still reads my next payment cycle & amount due will be $30 instead of the new $25 I've set it to change to.
Any clarification on this would be great, cheers!
Accepted Solutions
Highlighted
Re: Switched plans for the next billing cycle, still showing the old amount
Hi @Vault91
Welcome to Public Mobile!
That's how that screen works. You won't see the new plan details there until after your renewal.
BTW think hard before your next renewal, because the $30 plan is no longer offered. If you want to change your plan again later on, you always have to pick from the list of available plans. If needed, you can cancel your pending plan change, if you do it before your renewal.
All Replies
Highlighted
@Vault91 hi that will remain the same until the actual renewall date since it hasn't changed yet
Highlighted
Hi @Vault91
Highlighted
 @Vault91
It's not a great system. It only shows you what's current. It doesn't know that you've scheduled a change. And yet it does. Go figure. It's not a great system.
It would be suggested to manually deposit enough to cover the higher cost plan. After the change, it will leave the excess in your account.
Also be aware that changing out of a plan that is no longer available means you can't go back to it.
Highlighted
@Vault91
You'll receive the usual "Public Mobile here..." notification informing you that your plan was successfully renewed.
Probably best to clear your browser cache and cookies at this time, before you login Self-Serve to confirm your plan status. Just to prevent any browser-related stupidities from confusing things.
