Great to know. Another little trick in the toolbox
I'm having the same problem. I have sufficient funds/credits. How do I load a few on to my count?
@Douce go to payments then the there should be an option to add funds and select other amount and put in 1$
Fantastic information to share along! Will remember this post if people are asking.
So if this little jump-start kick of adding a little payment to your account actualy works, then I would suggest that Oracles be giving a bunch of $1 or $2 voucher codes that they can hand out via private message to offer as a possible solution to people.
The goodwill would far outweigh the cost and the Mods would not have to get involved. It would be easy to administer or check for abuse as I am sure you could track the codes.
@smp99 wrote:So if this little jump-start kick of adding a little payment to your account actualy works, then I would suggest that Oracles be giving a bunch of $1 or $2 voucher codes that they can hand out via private message to offer as a possible solution to people.
I like the other trick of toggling the lost/stolen feature as it doesn't involve money. But if that doesn't work then sure a nice $1 voucher to try the other trick. And then that doesn't work...
TELUS paying for proper code investigation and development is the better solution for all the issues. Fix it - and maintain it.
I am going to try this and hope that it works. Thank you!
