Reply
Re: Renew
@ShawnC13 wrote:
@popping wrote:
@Sharry19 wrote:
For example: If my current plan is ending in January end then If I renew it in April end (just on 89th day) my number won't be deactivated ?
You need moderator help to re-activate your plan after suspension.  Make sure don't leave it to the last day as moderator wait time is about 3 days or more.
@popping, you shouldn't need moderator help.  You should be able to add money and make a payment without moderator intervention.
Thanks for correctling my mistake.  I revised my post.
Re: Renew
@Sharry19 wrote:
Just wondering when my number will get deactivated if I don't renew my plan after 30 days?
@Sharry19 to add to what others have indicated... once your plan lapses beyond the 30 days without renewal/payment, your self-serve account should show an "Account Deactivation Date" in the payment panel just above the Account Status section (something like the following):
Keep the deactivation date in mind and if you reactivate before the deadline, you can retain your plan, number, etc.
A heads-up that there's a glitch in the AutoPay Reward, when you do this, if you have automatic top-ups enabled... you are likely not to get the $2 rewards when you resume (even though automatic top-ups will occur).  A possible workaround would be to remove your credit card from the system, and then add it back and enroll in AutoPay upon resumption (theoretical -- not yet proven).
Re: Renew
Why my number was désactive
