Reply
Highlighted
Re: Paying for plan with account balance
Thanks for assisting maybe this picture will help you understand more hopefully.....I did not put the $25 on the account. Shouldn't  the amount on the balance be able to cover the amount due regardless of the plan being $45Thanks for assisting maybe this picture will help you understand more hopefully.....I did not put the $25 on the account. Shouldn't the amount on the balance be able to cover the amount due regardless of the plan being $45
Highlighted
Anyway the available funds are not sufficient to cover your plan....I don't know where the 25$ come from...
Highlighted
Okay so the amount due is incorrect?
Highlighted
No it's correct...you still need to pay 19$ to top-up your account.. @candice1
Highlighted
Okay i think i understand now, how do i set up autopay though?
Highlighted
@stonechucker or @RobertQc could you have a loock here..I'm not sure if I understood well @candice1...
Highlighted
Here @candice1..
MANAGE AUTOPAY.... on right...
Highlighted
HI, so yes your plan is $45 and you have $26 in available funds. You can use what is available but in order to renew the current plan you need to add the $19 that it says. I suggest looking at the plans and deciding which you would like prior to adding funds. As soon as you add enough phones the plan will renew and use up the funds.
To add a CC or Debit card just click on the autopay tab.
Take a look at the $40 plan, it is very popular.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
Highlighted
Okay im using a laptop so i dont have those options
Highlighted
Ok...it's not here @candice1 but in your selfserve account....
