10-04-2021 01:44 PM - edited 01-06-2022 03:29 AM
I can.,t sign in and my card # has change for payment
10-05-2021 08:27 AM
10-05-2021 08:10 AM
@Bluegrasser - you need to go into your account, then make a payment area and at the bottom is manage my card, and then remove or replace your card. I think when I did mine I just did replace my card and that worked for me. Good luck!
10-05-2021 08:04 AM
i have new bank new card number
10-04-2021 04:42 PM
@Bluegrasser wrote:I can.,t sign in and my card # has change for payment
What kind of error message do you get?
10-04-2021 01:51 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck...
10-04-2021 01:48 PM - edited 10-04-2021 01:49 PM
@Bluegrasser You need to signon to My Account to change the payment info
did you try Forgot Password link? Enter the email you have used (or entered any email you might have used). Once the correct email is entered, you will get to the Security Question. Provide the answer and you can reset the password
If you are unable to get through Forgot Password to reset , you will have to open a ticket with PM to have the CS agent to sort it out for you
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
Once you are able to get onto My Account, go to Payment Tab, Manage my card and then Replace this credit card to change the card info
10-04-2021 01:47 PM
Try using a different browser and incognito mode. Also try clearing your cache and cookies then reboot.
10-04-2021 01:45 PM
@Bluegrasser : Did you try the Forgot your password? link? Are you using the proper email address as the login id?
