How I can pay my mobile number?
NG2
mo1979ca
There are a few ways you can pay your bill.
1.You can login to your account and use a debt card or credit card.
2. Use a public mobile voucher  (I used to buy mine from London Drugs)
3. You can sign up for auto pay and they will take it out of your bank account or credit card on file. (If you use this option you get 2 dollars off the 2nd auto pay and then after too if you keep auto pay.)
4. Rack up points from different public mobile programs like refer a friend or answer questions on this forum.
popping
@NG2
Some store does not avtiavte the PM topup voucher right away.  Ask the cashier on how long is the wait before use.
Shell gas station activate the PM topup voucher right away.  If you want to get your PM service running ASAP, try the topup vouicher from Shell gas station.
hairbag1
Get a payment voucher at your local 7-11 type of retail strore. Then call 611 and enter the 12 digit code number when prompted and you'll be good to go.
Be aware that some retail stores don't "activate" the vouchers until several hours after the sale.
Alternative is to look at an on-line payment service like recharge.com or ding.com...there's a small service charge for these ones.
geopublic
@NG2
Setting up AutoPay means that you earn $2 every 30 days!
To set up AutoPay, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
Two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info
Note: When entering the postal code do not enter any spaces. Also do not use the unit number field even if you live in an apartment or condo and use a desktop browser if you can.
Hope this helps!
GinYVR
@NG2You can use vouchers or with Canadian visa debit or credit cards via the selfserve to pay for your mobile number.
