Do I keep my phone number if i do not pay for next month?
Scarlet
Hi,
My billing cycle ends on Sept 14th and I want to keep my phone number till Sept 20th and port out, but do not want to pay for another month of service. I read that if I turn off autopay do not pay the service is suspended and I can keep my phone number, is that true? What other option is there for me to keep my phone number?
10 REPLIES 10
ccdevmike
Ok thanks for the info
@Scarlet wrote:
I preordered the pixel 4a and I should get it by Sept 15th-20th. I want to port my current number to an esim and used the sim card slot for dual sims.
@Scarlet  Nice phone!! So, I'm assuming you are going with Lucky. If that's the case then you need switch to the $15 plan then you have 30 days to port out.
Scarlet
I get a price with 1 sim talk and text and the other sim data only with competitors.
ccdevmike
May I ask why your leaving PM?
Thanks
Scarlet
geopublic
@Scarlet wrote:
Hi,
@Scarlet  As mentioned your account must be active so why not port out on Sep 13 why does it need to be the 20th?
@Scarlet Unfortunately you will need to pay for another month. Your account needs to be active. I believe that can be by passed if you are porting out to Koodo or Telus.
@Scarlet wrote:
Is it possible to suspend for the few days I need, or will I be required to pay another month of service regardless to reactive the account?
The account needs to be active to port. (not starboard 🙂 )
Scarlet
@Scarlet wrote:
Hi,
Unless you're moving to Koodo or Telus your account needs to be active to port.
You can keep a suspended phone number for 90 days. But you can't port out from a suspended account.
Downgrade to the $15 plan on the 14th/15th. Port out whenever you like.
