Reply
Change Credit Card Information for Autopay
I would like to change my credit card information (Autopay) for my Public Mobile account. How do I go about doing that?
Mike...
Re: Change Credit Card Information for Autopay
Mike...
Go to selfserve.publicmobile.ca. After logging in, clicking on the Payment option will bring you to the right place.  There is a an option called Manage My Card.
Hi @mftakahashi
Going to myAccount -> payment -> Manage Autopay should help
This is where you can update your card information for AutoPay
@computergeek541 wrote:
Mike...
Go to selfserve.publicmobile.ca. After logging in, clicking on the Payment option will bring you to the right place.  There is a an option called Manage My Card.creditcard.PNG
when you go on the page to pay there is a link under your card to change or remove it
Mike...
@mftakahashi  If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
Two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info
Note: When entering the postal code do not enter any spaces. Also do not use the unit number field even if you live in an apartment or condo and use a desktop browser if you can.
Hope this helps!
