Reply
Autopay
What is the minimum readymade Plan I do need to activate Autopay discount ($2 discount/month) ?
Re: Autopay
10$ / 30 days Smiley Happy
-2$ for autopay = 8$ / 30 days
Enjoy Smiley Happy
Re: Autopay
@Sharry19
10$/30 days is the cheapest plan...8$ if you Choose to enable autopay..
Re: Autopay
According to their website ...
To be eligible to earn Rewards, you must have:
1. A Rewards-eligible plan:
  • All in-market plans as of January 27, 2015, with the exception of 10-day plans, are eligible for Rewards. Plans offered between May 9, 2014 and January 26, 2015 are not eligible.
2. An active account:
  • Your account must be active and in good standing to earn and use Rewards. It cannot be in a suspended or deactivated status. For example: if you earn Rewards and immediately go into a suspended state because of a late payment, you will not be able to use your Rewards until you have made that payment.
  • Your Community account must use the same email address as your Self-Serve account in order to receive Community Rewards.
So I believe should be any plan offered now.
Re: Autopay
Just wondering If I change the plan how this Autopay will work? Do I need to make changes to Autopay or simply just change the plan & Autopay will take the money according to new plan $value ?
Re: Autopay
No need to do anything on autopay. Autopay will do the calculation for the amount to take out from your cc according to your current plan and rewards at the renewal date.
