05-27-2020 04:09 PM - edited 01-05-2022 12:03 PM
so my account is set up on autopay but for some weird reason the payment didn’t go through so I try to make a manual payment but the system keeps saying unable to process your payment so what do I do??
05-27-2020 05:04 PM
@Pur3aznboi You may reactivate a suspended account online or by calling 611.
Via your account online
1. If you have already registered, or will first register, a credit card, go to step 2. OR deposit a voucher for at least your plan cost and go to step 3.
2. Go to the payment tab, select single payment and amount due.
3. Select the reactivate account button.
4. Restart your phone.
or Using 611 to make your payment: ( you need your 4 digit pin to buy an add on)
1. press 1 to make payment
2. press 2 credit card ( or 1 voucher)
3. press 1 amount due.
Stay safe
05-27-2020 04:26 PM
@Pur3aznboi Try calling 611 and making payment through there. If you can't, try to replace your CC in your self-service account. You also can buy vouchers and use them to top up the account.
05-27-2020 04:17 PM
@Pur3aznboi wrote:so my account is set up on autopay but for some weird reason the payment didn’t go through so I try to make a manual payment but the system keeps saying unable to process your payment so what do I do??
@Pur3aznboi Unfortunately AutoPay will fail from time to time. Try making a manual payment and select custom amount and enter the amount owing + $1 to see if it works.
If not, then try removing the CC and try re-adding it. If you would like to change/re-add the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
Two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info
If you're having trouble registering or updating your credit card, here are a few tips you can try:
Hope this helps!
If you still can't solve it then submit a ticket to PM and ask them to clear the security lock that might have been triggered because of too many attempts to make payment.
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
05-27-2020 04:13 PM - edited 05-27-2020 04:19 PM
Can you try calling 611 to and make a payment?
