10-09-2018 04:34 PM - edited 01-05-2022 05:52 AM
I have 3 numbers under my name with public mobile. I have set up auto withdrawal for one mobile number. How can I register the other 2 numbers for payment on this account as well?
10-15-2018 02:26 PM
@sally1951 wrote:I have 3 numbers under my name with public mobile. I have set up auto withdrawal for one mobile number. How can I register the other 2 numbers for payment on this account as well?
Hi,
Were you able to set up auto payment for all your accounts? If so, it would be great if you marked this thread as solved so future readers can see how you went about fixing the issue!
10-10-2018 06:29 PM
Hi,
To my knowledge you are only allowed one number under one account with Public Mobile.
Therefore, if you have those 3 numbers, you must have 3 separate accounts.
Furthermore, since you used your credit card for the first mobile number, you can use it for only one more. I believe only two accounts can use the same credit card number and it goes to error after that. So your final number needs to be on a different credit card to register for auto-pay.
10-09-2018 05:12 PM
It looks like you can register the same credit card for the separate numbers. However I believe you need different Self Serve account for each Public Mobile number. I have two numbers with Public Mobile on separate self serve accounts but using the same credit card.
10-09-2018 04:48 PM
Yes you will have to set up autopay on each acct, but you can use the same credit card so it all comes out of one acct.
10-09-2018 04:40 PM
Only one number may be managed per account; so, you're stuck with 3. Hopefully, that means you registered for 2 referrals.
10-09-2018 04:39 PM
If you are referring to auto-pay, loginto selfserve for each account add a credit card and then enable auto-pay.
10-09-2018 04:38 PM
You can register more than one account for autpay off of the same credit card. You will need to login to self serve and go to payments manage payments and add card I believe. I have always set mine up upon account activation.
