Auto pay did not take payment
a_fakename
Hi there, auto pay did not take payment for July.  My serviced has been suspended.  What should I do, wait for the correction?
14 REPLIES 14
@a_fakename if you really need your service activated you can purchase a voucher from
https://www.recharge.com/en
this is how to create a ticket using SIMon
https://productioncommunity.publicmobile.ca/t5/Discussions/Easy-way-to-open-a-ticket-via-SIMon/m-p/5...
@a_fakename  Hit the ? Bottom right of your screen.
a_fakename
How do I submit a ticket?
a_fakename
Just tried again to manually pay, it was unsuccessful.  Message blames card, but card is good.  Made purchase today and has already been posted to account.
@a_fakename
@a_fakename wrote:
Thank you.  I did try to make a manual payment, when I first discovered my phone wasn't working, but I got a bounce back message from Public mobile.  I have checked my credit card and all seems well.  I will try the ticket thing you suggested.
Moderators will probably respond by tomorrow sometime.
Website can be finicky.  You can try to clear cache, incognito mode or another web browser.  Try to manually load funds again.
If you can't manually load funds via self service account, you could try dialing 611  from your phone to load up funds
https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352
@a_fakename wrote:
No service =(
@a_fakename
Follow the instructions above.  If no service, you will need to manually load up funds equivalent to your plan fee.  Then it should restart your plan.
a_fakename
@a_fakename login to your self serve account and make a manual payment. once you have "available funds" you can click the reactivate button
if you still can't make a payment you can contact customer support here to create a ticket
https://publicmobile.ca.ada.support/chat/
make sure to check your inbox(top right corner envelope icon) periodically, for a message
a_fakename
No service =(
a_fakename
Thank you for your response, no my .service does not work
geopublic
@a_fakename  If your phone is currently not working then try to make a manual payment for the amount owing + $1 and hit the reactivate button to get your service up and running again.
If it doesn't work the submit a ticket to PM and ask them to fix the issue.
@a_fakename  if service still works then that's normal renewal process.
Account goes.
  • Active to Expired
  • Then once system updates it goes from suspended back to active.
I believe this is the text that @Anonymous  was referring to.
Is your phone still working?
@a_fakename  If you try to use your service, does it work? I ask because at the time near renewal, the self serve account will erroneously report expired plans and suspended accounts when they aren't.
If your services are still working then let it do the renewal overnight. At noon ET you should get a text saying all is well. (not those words)
