Reply
Accessing account
I have two PM accounts for two separate phones. I received a text on each saying my CC was expiring. I had no problem updating my CC on one phone but when I try to sign in to the other I keep getting logged into the same account. When I try to register the second phone again I get the error message that the phone does not exist.
How can I access the account on the second phone? That phone does not have data so I can’t access the link in the text telling me to update my CC. The phone works and autopay keeps taking my money so the plan must be somewhere!
Re: Accessing account
Fully, properly log out of one. Then clear cache/cookies and then log in to the other.
Each account should be created with a separate email address.
Check the email received from PM after each activation.
Did you use different emails whe you setup the accounts?
Do you have a selfserve account for both phones?  If you activated in a retail location you are required to set up self serve accounts for both as each phone number is it's own account.  You could try to chance the credit card through 611 I think I remember someone mention they could manage payments that way.
* I am happy to help, but I am not a MOD please do not include any personal info in a private message to me, click here to private message a Moderator *
611 doesn't let you add/edit/delete a cc. Only payments if registered or toggling autopay on/off.
@Elaphus First of all if you have two separate lines then you should have two separate PM accounts with separate email ids.
Are you sure you have two separate accounts?
If yes then please fully Log out from first account and log in to sencond account. You should be able to do it.
If still there is a problem, then please send Private message to Moderator by clicking on this lick @Moderator_Team
**** Please note: I am not a Moderator ****
@Elaphus
As z10 said, clear the web browser cache. Ensure you also close web browser for several seconds, relaunch it. Also try a different browser, or a different computer.
Same thing happens to me . In my case I have to clear my MacBooks history . Also check your security settings because in my case I also had to enable accept cookies for PM.
