transfer number from Koodo
Mach1tosh
Just signed up and not finding too much info on transferring existing number from Koodo.
Help please.
popping
@Mach1tosh wrote:
I seem to be having issue with getting new number up & running.  Still getting "emergency calls only" and not able to make outgoing calls or text.
Restart you phone with PM SIM card installed.
If it is still not working, try your PM SIM card in another phone to rule out hardware issue..
You can also try the lost/stolen phone trick.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
If this trick failed to get thing working again, you should send a private message to moderator for help. But the wait is up to 48 hours. Good luck.
Mach1tosh
Lorca
Help please.
If you have a monthly plan with Koodo, pick a new number at Public and after it’s up and running go into your account to transfer your Koodo number over. If you’re with Koodo prepaid, pick a new number when you set up with Public and then contact the “moderator team” to complete the Koodo prepaid port.
popping
Help please.
If you have a Koodo prepaid number, to need to send a private message to moderator to port your Koodo prepaid number to PM.
Moderator wait time is up to 2 days.
If you have a Koodo postpaid number, login to self-serve and select [Plan and Add-Ons]--> [Change Phone Number] --> [Transfer a wireless or wireline number ]
GR
Koodo prepaid or postpaid ( monthly)
