setting up apn
taz1
Help please!!
I'm trying to set up the apn on my new phone. It's an lg phoenix 3. Can someone tell me what to enter?
Name not set
APN not set
Proxy not set
Port not set
Username not set
Password not set
MMSC not set
MMS proxy not set
MMS port not set
MCC 302
MNC 220
Authentication type not set
APN type not set
APN protacol lPv4/lPv6
APN roaming protacol lPv4/lPv6
Thanks for your help!!!!!!!
will13am
@taz1APN settings are not phone specific.  The suggested site rather awkward to use because it sort of suggests that.  Use the information here.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
taz1
Thanks. I had tried there but they don't have the model I have.
Went back and picked a model at random(harmony) and tried those settings and it worked. Hopefully anyone else having the same problem will find this and give that a try.
matbasm
Hi @taz1, you can find the proper APN settings on the following site:  https://apn-canada.gishan.net/  Enter the brand, then the model, and then select Public mobile.
