Reply
porting problem- cannot receive any incoming calls
2 problems:
1, I transferred my fido cell phone # to public mobile at 5pm Dec 1, 2019. But until 9:48pm, I still can't receive any incoming calls.
2, I never turn my cell phone option of "mobile data" on, but the data usage shows 600k has been used.
Re: porting problem- cannot receive any incoming calls
@publicy wrote:
2 problems:
Use Fido sim receive calls.  Get your Fido account number and open a ticket clicking the question mark and type in talk to rep.
@publicy
The port from Fido should usually be completed in a couple of hours.  Maybe wait until morning and if port is not completed, you will need to contact moderator.  Moderators are not working right now anyways.
Click on the question mark on the right lower corner of website to start ticketing process to contact moderator.  Type: Contact moderator. Follow the prompts to submit ticket.
There is sometimes leakage of data when you activate a plan or phone.
@publicy  There has been a bit of an issue with porting from fido this weekend which is not usually the case. In my own experience it took no more than 5 mins. If it's longer than 2 hours and in your case almost 5 hours your port is stuck. Hopefully by now you have submitted a ticket or a private message to the moderators. They are a little busier this weekend but should get back to you within the first hour of business Monday morning....by 9am et. However the telus porting department  opens I believe an hour earlier at 7 am et. Try calling them if you prefer not to wait or can't wait and they should be able to sort out your porting issue if access to your pm account is not needed. Have your fido account number ready. 1 877 868 3587 prompt 1. English  prompt 2. Representative
I believe it was the setted up issue, I do not know where did you do it , if you convenient, go back to store where you did. If you unable to go back, then sign in to your online account ,sent community ‘s message, there will be some one to check and fix your problem, good lucks!
Retail locations are not a point of customer support for Public Mobile customers. They cannot fix a porting issue. They could potentially call in to have someone look at the porting issue, but so could the customer from home, or the moderators could do same for the customer using the normal ticketing process. I don't see a reason to for the customer to make a trip back to the store.
