Reply
Debster119
no internet
How do I make sure everything is set up right?
When I use my phone for ANYTHING but Facebook..
I get the message NOT REGISTERED ON NETWORK??
Please Help
TYIA
will13am
Re: no internet
@Debster119 , if your are able to use mobile data even on just one app then it's working.  Is it possible that apps are being blocked from using mobile data?  What model of phone are you using?
Re: no internet
@Debster119   your other apps working too?  Like Browser, Google Map , etc.
Debster119
Re: no internet
yes they work only when I am in my house when i leave the house my phone does nothing but use camera or video
Debster119
Re: no internet
Samsung galaxy 10
Re: no internet
Look like your Mobile data is not setup yet.. Something to do with APN
what model is your phone?
Was it working with another provider before/
Re: no internet
Galaxy 10 certainly work on PM
You sure you didn't disable Mobile Data?  ?  Make sure it is enabled.
Also, what is showing on APN
Try a network reset
and this is the APN setting for PM
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
Re: no internet
Not registered to network is a message that means that you're not conected to the mobile network.  This can be because the wrong network is selected, there's no service (ex. not activated or cancelled), or this can sometimes happen when there's a network problem.   Can you try reselected the automatic network selection option to see what happens?
Re: no internet
APN settings not being set wouldn't preent the connection to the cellular network  APN settings also wouldn't affect phone calls or text messages.
Debster119
Re: no internet
where would I find that?
