04-02-2019 03:09 PM - edited 01-05-2022 04:07 AM
I paid the amount and activated my sim but my phone number is not activated
04-02-2019 03:19 PM - edited 04-02-2019 03:23 PM
@Sebeika1 wrote:I paid the amount and activated my sim but my phone number is not activated
Are you porting your number from another provider? If yes, it won't work until the port is complete. Restart your phone and see if you can make outgoing calls. If yes, then you need for the port to complete or just use your old SIM card until it stops working and then swap SIMs again.
If you are not porting your number and have verified that your phone is compatible with PM then you need to send the @CS_Agent a private message by clicking here and they will help you.
