Reply
Re: international calls is not working
@Slinxci wrote:
@jackfzhao wrote:
could u pls show me the format u dial?
for my example, guangzhou............0118620xxxxxxx, tianjing.................0118621xxxxxxx
I was calling Fujian provice, dial 011860591xxxxxx, or  +860591xxxx, and 01186591xxxxx, no one works
that's weired, i assume u have the right addon working because u mentioned u can call cellphone in china, 01186591xxxxxx is the right way to call, what did u hear when u called? did u try any other #?
pm1
hi, did you get the problem solved?
i am planning to get the LD add-on, but i am afraid i will face similar problems...
No, You can call international cellphone, but can't call fixed line telephone.
It said 6UN1, the nubmer you have reached is not in service. or 8UN3. every time, when I call same number, it gives me different code.
i just tried, 01186310xxxxxxxx, +86310xxxxxxx, both are working fine
one more try to another city, also fine, +86898xxxxxxxx, pls make sure the # u dial is valid, then contact mod, good luck
@Slinxci wrote:
I have 400 minues long distance add-on, and tried to call my grandparents in China, I use exist code+ country code+ province code + fixed line telephone number. There is always a error, I can not call fixed line telephone. but it works, when I call a cellphone. if this add-on only work to international cellphone,or I have to change setting to make it work to fixed line telephone.
I think this should alredy been resolved as it was more than one year ago~
Make sure you DO NOT include the "0" for city or provincial area code;
For example, when you dial beijing (area code 010), use +"118610" not "+1186010"
For future reference of new PM members...
