Reply
international calls is not working
I have 400 minues long distance add-on, and tried to call my grandparents in China, I use exist code+ country code+ province code + fixed line telephone number. There is always a error, I can not call fixed line telephone. but it works, when I call a cellphone. if this add-on only work to international cellphone,or I have to change setting to make it work to fixed line telephone.
Re: international calls is not working
When you purchase add-on did you follow the 2 step process first you purchase add on and fund get transfer from cc to public mobile funds then you buy again same add-on from available funds. ?
** I am not a Mod, please do not include any private info in a private message to me.**
as i know, the provincial code in china like 010, 020..., did u remove the 1st 0 n type it like +8610....., +8620....?
@Slinxci wrote:
I have 400 minues long distance add-on, and tried to call my grandparents in China, I use exist code+ country code+ province code + fixed line telephone number. There is always a error, I can not call fixed line telephone. but it works, when I call a cellphone. I am not sur if I can call a fixed line telephone.
Yes, I can see the add-on in my account.
I tried 011860XXX, +860XXX, no one worked
Does the 400 mintues show up on your self serve.?
 Just saw the reply
remove the number 0 behind 01186
I tried, not work
could u pls show me the format u dial?
for my example, guangzhou............0118620xxxxxxx, tianjing.................0118621xxxxxxx
I was calling Fujian provice, dial 011860591xxxxxx, or  +860591xxxx, and 01186591xxxxx, no one works
