Reply
Highlighted
how do you know if APN settings is correct?
how do you know if APN settings is correct? thanks
Accepted Solutions
Highlighted
Re: how do you know if APN settings is correct?
@LD1 Compare what you have set in your phone to below;
All Replies
Highlighted
Highlighted
Highlighted
@LD1  try these taken from my phone.
Or try these
Highlighted
The easiest way would be to see if the services work. Disconnect from Wi-Fi and try loading some websites.  Also try sending or receiving some MMS.
Highlighted
If your data and mms works without any WiFi settings are good
