confused
Marias_Man2016
i bought a replacement phone and transfered sim card everything is worki g great till i went to use my data and turned it on everything looks good but have no data at all....wifi text phone calls everything is working but my data can someone help
Marias_Man2016
yes i put in all the values for the APN and it worked i never knew about the APN i was looking at it too
jp2
Hopefully it will work for you once you input those settings using the link I provided. Let us know if you still are having problems
Luddite
a) Make/model of your new phone?
b) Do you see data under My Add-ons in your account?
Marias_Man2016
no i didn't set up APN settings wasn't sure what they were supoose to be
jp2
Did you put in the right APN settings?
For data to work on your phone using the Public Mobile network you must setup the APN (Access point names) settings. Click here to see the APN setup article.
