Reply
Highlighted
change phone number
its been 3 weeks im trying to change my phone number and the message i receive its always the same: phone number change failed...my account is active...please help me...
Highlighted
Re: change phone number
Stay safe
Highlighted
You can only change your number once per 30 day term.
Perhaps try a different browser or clear cache or use incognito/privacy mode.
Edit: ninja'd
Highlighted
Sounds like you need to contact a moderator to help you out.
Highlighted
@tonyluckyboy
You can only change phone number once per 30 days.
But you can port a number to PM without the 30 days limitation.
I had port two numbers to the same PM account with 2 weeks in between.
Highlighted
There are 2 ways you can change your new
1) either get a new number which you can do once every 30 days
2) transfer your old number for which you would have to send a private message to the moderator
hope this helps!
Highlighted
hope this helps!
Generally, customers do not need to contact moderators to port in a phone number, a number coming from a prepaid Koodo account being the main exception.
Highlighted
hope this helps!
Now that's a hedge word. "Main". 🙂 Isn't there also like a PC Mobile or something? Also I gather TextNow.
