Reply
change phone number
I just joined Public Mobile last week. I was hoping to keep my phone number that I had with Koodo, but its not working. I followed the online instructions that said to make a new one and then I could switch back later, but when I type it my old number it says its not available. Any help would be appreciated!
Re: change phone number
Your old account with koodo must be active and in good standing in order to port the number out.
@stapes328  It's not clear. What is not working? Did you have a Koodo prepaid account?
>>> ALERT: I AM NOT A MODERATOR. JE NE SUIS PAS MODERATEUR.
I now have new phone number, but I'd like to switch back to my old one. I don't have an account with Koodo anymore, but the instructions online said I could keep my phone number if I had an account with Koodo.
But The koodo account NEED to be ACTIVE for port the number...
In order to port your number from Koodo your account needs to be active. When did you close your account? Can you login into your Koodo account online? If yes, then you can send a private message to the @Moderator_Team  and see if they can help you.
If you have cancelled your account with Koodo before porting the number than it has been lost. Koodo gets it back. As mentioned you need an active in good standing account to port the number out.
I didn't cancel my account, I just put in the new SIM card for Public Mobile. I've never logged in to my Koodo account....I'll see if I can. Thanks!
@stapes328 Put your Koodo SIM back into the phone and see if you still have service.
I checked and its no longer active.
