Reply
Highlighted
cant send texts with pictures to Android users
Hi there.
i just switched to PM. somehow i cant seem to send texts with photos to Android users.  Is there a fix to this?  I have an iPhone 11 pro
Accepted Solutions
Highlighted
Re: cant send texts with pictures to Android users
@makenzi wrote:
Hi there.
1.  Sending MMS needs mobile data. Is your data working on your browser?  If not, you need the PM specific carrier file to be updated.  Check your iPhone for update.  You may need to connect your iPhone to itune running on a PC to update the carrier file.
2.  If you data is working, you need to configure iMessage to send SMS/MMS as follows:
Under iPhone Messages settings:
iMessage = enabled
SMS/MMS
MMS Messaging = enabled
Group Messaging = enabled
All other Messages settings are disabled
How do you know what message type you are sending or receiving on iPhone?
Messages with green bubbles are normal SMS/MMS text messages.
Message with blue bubbles are sent via the iMessage
All Replies
Highlighted
@makenzi wrote:
Hi there.
Check your apn settings.
https://apn-canada.gishan.net/en
Highlighted
ok, i just did.  it says APN isp.mb.com
blank for username and password (is this something i set up? do i use my PM info?)
thanks for your help
Highlighted
Try with no i. The pic is from my iPhone SE.
Highlighted
not much of a techie.  what does the apn settings do?  I checked it and it shows as
IPN isp.mb.com
Username.    blank
password.     blank
would putting in a username and password solve my issue of not being able to send photos via text to androids?
Highlighted
IPN isp.mb.com
Username.    blank
password.     blank
No....it won’t take.
Highlighted
Make certain that your data is enabled.
Highlighted
so just double checking, i need to turn data on for sending pictures, correct?
i can send regular texts without turning data on, right?
Highlighted
@makenzi  yes and yes for your questions.
And make sure to change settings on your iPhone for SMS and MMS
Highlighted
To an android user yes...any time....every time.
To another Apple user you MUST have either Data or Wifi connected.
