Reply
can't use the phone with $10 plan
I changed my plan from $40 to $10.
It worked when it was $40, but now I can't use the phone. Every time I try to make any call (Canada wide) I get the message "Long distance call is not included in your plan"
Re: can't use the phone with $10 plan
What's included in your $10 plan? Is it data-only or does it include voice calls?
Try this little trick to reactivate your sim...go in your self-serve account ..tab PLAN/ADD-ONS and click on PHONE LOST/STOLEN  and close your phone few minutes. Open it again and click on reactivate your service. Does it hep?
If not write a message to the moderator here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 they will help you with that. Waiting time is up to 2 days..usually.
Does your plan include the talk feature? If not, you cannot make any calls.
If talk feature is included, do you have the long distance add on? It looks like most likely not.
How long ago did you change the plan?
If just last night then the idea mentioned by Lieux might work.
If some number of days ago then maybe you've used all the 50 minutes in the plan.
@dibr When you log into your self serve account, what plan do you see?  Have you tried restarting your phone?  If the new (correct) plan shows in self serve, you can try the lost/found phone trick.  Report the phone lost.  Wait a few minutes, then report it found.  Then restart your phone.  This often helps if you have a plan but service is not working.
