05-15-2018 04:39 AM - edited 01-04-2022 04:17 PM
I have been playing around with the different base plan pricing, and discovered that it costs the same whether or not data is selected. Why is this? Shouldent it be lower if you select "No Data"?
Or is the 1GB 3g data considered a freebe?
05-15-2018 04:26 PM
@BrandonBerner as @kav2001c noted, Public Mobile allows you to pick and choose the service(s) you want, but the more you choose, the larger the discount. In some cases, adding a 3rd service will increase the discount enough to either completely offset (negate) the extra cost of adding that service. If you'd like to think of it as getting the data for free, then that's cool!
If you were just looking for talk + text, it's actually $5 *cheaper* per month to pick the 500MB of 3G-speed data as well, for $30 instead of $35 for just talk + text. So that might be an option for you.
05-15-2018 07:49 AM
Public has always given a larger discount with pick3 options
