Wanting to Switch Over - Three Phones
Willie888
Currently an unhappy customer with another carrier.
Looking to switch over three phones (and perhaps a fourth), and am looking for the best possible deal.
What I need: Local calling and 1 GB of data per phone.
That's it! What can you do for me.
ShawnC13
So if you go to build your own plan you do build it to suit your needs.  I have looked at it for you and this is what I found.
30 days
Provincial Calling Internations text and 1GB 3G(LTE LITE) is $35 if you sign up for autopay it is $33 a month
Same plan with LTE speed is $42 with autopay it would be $40
90 Day plans
Provincial Calling international texting 3GB (over 90 days) 3G is $105 with autopay $99
same plan with LTE is $120 or $114 with autopay.
Also if you are moving over multiple lines you can also earn a referral bonus for each line you bring over of $1 a month.  If you don't know anyone with PM message me and I can I give you a referral number for your first line and then each of the other lines you sign up use your number toe arn the additional $1 off a month.
Cheetah24
Hi there,
Thanks for considering Public Mobile. All the plans are outlined here.
https://www.publicmobile.ca/en/bc/plans
You can also build your own plan at the bottom of the website. If you need 1 GB of data, you'll probably be looking at the following plan.
https://www.publicmobile.ca/en/bc/plans/35for1GB-3G
Let us know if you have any further questions. 🙂
Thank you.
LEGO
Click on Plans at the top of the web page >
Look at Featured plan or check Build your own plans for more flexibility
LEGO
Check here for Featured plan or check Build Your Own plans for more flexibility
https://www.publicmobile.ca/en/on/plans
LEGO
