Voicemail Storage
Bejksc
the voicemail stored for 10 only and it is not enough storage for my usage, by any chance to increase?
10 REPLIES 10
trishe
It would be great to have that option for those who need it
srlawren
@Lar wrote:
I'm still new here so this may or may not work but I think you can use Call Forward to any number which in my case is the home answering system which I have complete control of message storage. Check out Call Forward in the help section. Cheers
@mimmo wrote:
people have also forwarded calls to voips like fongo, and allow fongo to handle voicemail.   the nice thing here if i remember correctly,  is that  fongo has a visual voicemail type system,  so you dont have to go through every single message to get to the last one.
@Lar@mimmo@Bejksc  yes these are options.  BUT, beware if you have the $10 or $15 plan (anything with a limited number of talk minutes), because call-forwarded minutes use up your limited airtime.  If you had 10 people leave you a 5 min voicemail message within a 30 day period, you'd run out of minutes without making or receiving any additional calls.
srlawren
@Alex888 wrote:
@BejkscNot without changing your plan, I think a few of the more expensive plans allow more storage.
@Alex888 no, there is a single voicemail offering with no upgraded options available on any plan.
@Bejksc wrote:
I did check for changing plan for more voice but there's no mention about voice message, that's I kind of lost about it.
@Bejksc  correct, there's no option to get more.
Bejksc
Noted with Thanks
Bejksc
noted with thanks
Bejksc
mimmo
Lar
Lieux
That's Simon told me...
A maximum of 10 messages may be stored, with a maximum length of 5 minutes each.
Keep in mind, voicemail messages will be automatically deleted after 10 days....
in any plan...
Alex888
@Bejksc Not without changing your plan, I think a few of the more expensive plans allow more storage.
