06-25-2019 07:18 PM - edited 01-05-2022 05:34 AM
Hello,
I am transferring from Telus, however each time I try to import my phone number, the page times out. What do I need to do to keep my phone number?
Thank you.
06-26-2019 06:53 PM
This worked, thank you!
06-25-2019 07:40 PM
I had a similar issue. My suggestion is also to try during off peak period. If it is not working, connect with moderator team and generally they are quick in responding to issues.
06-25-2019 07:39 PM
06-25-2019 07:34 PM
Should they do it on their own or with the aid of a MOD?
06-25-2019 07:27 PM - edited 06-25-2019 07:31 PM
@tstahlI suggest you try it in evening / off peak hours. You usually get less chance of time outs.. as Public Mobile's system is rather limited.
06-25-2019 07:27 PM
Here is the knowledge article on porting:
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Activate/ta-p/251824
Most ports require the original carrier account number, account holder name and phone number. Generally, you will not need to contact Telus. Once ported, your Telus account will automatically close.
06-25-2019 07:26 PM
@tstahl You can first select a new number as temporary use. Then port your current number after.
