11-25-2019 09:13 PM - edited 01-05-2022 08:08 AM
11-25-2019 09:46 PM
@Fifi_26 A note on @Nazrinn advice. It is usually recommended to takes A temporary number first and make sure all your services get set up on your phone. Texting, data and calling. Then once everything is working correctly go into your account and click on change number. You can then port in your number. All you need is your account #, name on the account and an alternate number. You only need 1 of these three: acct#, pin# or IMEI #. The acct # is the least problematic of the three.
11-25-2019 09:44 PM
Number porting is a 2 stage process:
Stage 1. After submitted your porting request, PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] display?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If no, you should create a support ticket for moderator to investigate.
Stage 2. Now, you are waiting for your old provider to release you number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider.
11-25-2019 09:40 PM - edited 11-25-2019 09:41 PM
@Fifi_26 wrote:How can i transfer my number
Main points
-don't contact old provider to cancel; new provider does all the work for the porting
-number must be active
-have details like account number of old carrier
11-25-2019 09:37 PM
I'd base myself on geopublic answer's, but I'll add that if you don't have a PM account connected to your phone yet, and the phone number you want to use is currently tied to your previous cellphone carrier, you can just:
I've successfully transfered from Virgin Mobile to Public Mobile only in a few hours that way. No need to talk to your previous carrier before doing the transfer. It's really simple.
More info on how to transfer your phone number in Canada here: https://crtc.gc.ca/eng/phone/mobile/num.htm
11-25-2019 09:21 PM
@Fifi_26 To port your number read the following article.
https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
