Reply
Lamchute
Ticket Sent
How long does it normally take after a ticket is sent for a moderator to respond?
Accepted Solutions
JK8
Re: Ticket Sent
@Lamchute wrote:
It’s been 48 hours, I’d like my number switched from Telus to Public..
All you can do is be patient. You can always submit another ticket just in case. Make sure to put port request in the subject.
All Replies
Re: Ticket Sent
usually an hour or two. keep checking your inbox
(their official word is within 48 hours,  but most time it is quick)
Tags (1)
Lamchute
Re: Ticket Sent
JK8
Re: Ticket Sent
HALIMACS
Re: Ticket Sent
Being the week-end, I think it takes a bit longer for Moderators.
Here's the process, which you may already be aware, re the porting process:
https://www.publicmobile.ca/en/on/get-help/articles/port-fraud-protection
Luddite
Re: Ticket Sent
@Lamchute  If you've already requested a transfer, call the Porting Team at 1-844-232-7678 to re-authourize your number transfer.
Korth
Re: Ticket Sent
popping
Re: Ticket Sent
Always check your private message SENT box to determine whether you had created a ticket.  If not, create another ticket right away.  Otherwise, you will be waiting forever without reaching a moderator.
