Sorry, we cannot complete your call, you do not have the required long distance add on
nursepav
"Sorry, we cannot complete your call, you do not have the required long distance add on". I am calling local numbers. Also I am not getting incoming calls or texts.
11 REPLIES 11
Rockdaddy22
You'll definitely need a mod
nursepav
Its the same sim. I put the public mobile sim in a new phone and i get the same issues. I put my wifes sim from her phone into mine, her number works. The issue is with public mobile.
Rockdaddy22
Can't you get calls on your old sim?
nursepav
 I am a part time employee and i get called in the night before for a 12 hour shift. I highly rely on having access to my cell phone, and its been 3 days now and I cannot send or receive texts or phone calls. I should not have this type of down time, and no one from public mobile is fixing the issue. There is no phone number I can call for tech support. I contacted 4 moderators and no one is responding. I find this unacceptable, as I am losing income from not having access to my phone. I may have to find another provider as this is not my fault and the issue is not being addressed by public mobile.
nursepav
I have privately messaged 4 mods and still no response.
Rockdaddy22
@madhatter he mentions he can't receive calls or texts in the original post, definitely a good hunch. 🙂
@nursepav because you're also having issues with your incoming calls and text, yes this sounds like more of an issue than the area code as @madhatter has already mentioned.
If you haven't already, you should send a private message to one of the moderators. If you check out the Users Online page, moderators have this tag MODbeside their names. Hover over their name and you'll see a pop-up with Send Message in orange. It doesn't matter which moderator you send a message to, because your message will go into a pool that each moderator can see. Include your phone number or account number in that message.
nursepav
that is correct, nothing works
madhatter
I have a hunch it has nothing to do with area code. It's just the sign that your service is hosed, at least for now. I betcha you can't receive calls, or send/receive texts, or access internet.
Ask me how I know.
hslee1210
It is a glitch that some people had like the link below.
http://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Why-is-my-local-call-considered-long-dis...
You should send a message to a moderator to  get the issue resolved 🙂
Good luck!
jeferson
Have you PMd a moderator? They can help you with this.
Good luck!
jeferson
