Reply
Re: Someone has the same phone number of mine?
Why??!! It's not my fault. I bought this phone number on our website. Is it a bug?
@nico7nico7
Its definatlely not your fault..but numbers have been used before..  Its happened to me..you can stick it out..tell the people that call the situation..or change your number and start over...
It's definitely not a bug, and telecom company recycles the number that are not used, transferred, deactivated, bad account, etc. You know there are only so many permutations of 10^7 x n area code. Plus telecom companies have to always reserve lots of numbers for new account, or businesses.
At this point, arguing about who's fault will be basically pointless.
What I would recommend you to do is to get a new number.
Because the number you use could have some bad history, possibly a debt collector has this number, or God knows how the previous owner used the number.
Plus the number cannot identify you will cause lots of issues if you sign up with different organization that this number has been signed up.
Thank you for your reply. If I apply for change another phone number, Can I get a new SIM card or the number just changed automatically?
@nico7nico7
Same sim card....just change your phone number ....
You don't need to get a new SIM card.
Log in self serve, and then
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/msisdn-swap/
This link will take you to the
Phone number change
section,
@hzmy
👍...are you figured out now???
Yeah, it's a bug.  Assigning already active phone numbers seems to be a Telus (and other Telus owed brands) specialty.
One time, they assigned my number to someone else even though I already had it for a few years.  They had to give the new customer a new phone number.
Usually when this strange stuff happens, my experiences (both personal and from reading) have been that usually the second person to receive the number usually doesn't receive any incoming calls or text messages.   For you, you seem to have taken control of someone else's phone number. I know that this is no fault of yours.
I don’t use the apps that take over your phone number for use in data only messaging, but is it possible the the previous user of the phone number hasn’t updated their app for their new new number?
you’ve had this number for over 3 months now, I think you should be able to keep it.  How long has this been happening, is it just recent?
@nico7nico7
Its really not confusing at all
Someone else had the phone number
Registered the number in Whatsapp
Then either change the phone number or cancelled the phone number
Whatsapp has nothing in place to prevent this (some even call it a "feature" since while travel international you can swap SIMs and keep your old number)
Having said that, you have posted way too much info here since this is a public message board I would seriously edit out the pics of phone numbers / names
The only way to ensure your number is not the same as person using in Whatsapp is to change your number
Public can't force the former person to do so
@nico7nico7 wrote:
My name is Cong. I'm an international student studying at Halifax, NS, Canada. I got my sim card in September 2018. It's been bothering me a lot since I got my phone card. I always received message and phone call from other places called me Tobi? I tried to ignore them but it does bothers me more because I always received different calls and I'm even not sure if my phone number is safe to connect with my bank account and social media account. Yesterday, my classmates just found that there is another person use my phone number registered in whatsup. I'm so confused and what should I do NOW?
Looking forward to hearing from you soon!!!
Regards,
Cong Chen
