03-12-2020 10:39 AM - edited 01-05-2022 09:54 AM
Hi, I just activated my sim card. I had some issues doing it, because it wasn't recognised. I waited over night and this morning it seemed to work.
WhatsApp works, Instagram took 10 seconds, but now it works perfectly.
I could send text messages.
Ecosia (a browser such as chrome) doesn't work, it says there is no connection.
Chrome: some internet sites work, some don't.
I removed the SIM card, waited a minute and put it in again - now calls and texts work, but internet is still the same.
Did anyone has the same issue? What should I do?
Thanks, Bea
03-12-2020 01:42 PM
03-12-2020 01:36 PM
It worked! I changed the APN the way you suggested and now it works!
Thank you so much!!
03-12-2020 12:23 PM
Thanks to all of you! I'm at work rn, but I'll try all your tips in my break!
03-12-2020 12:14 PM
I would uninstall and then reinstall those apps that don't work.
03-12-2020 11:13 AM
@beawolpert correct these APN settings, settings , and restart your phone. Welcome to PM.
MMS proxy: 74.49.0.18
APN type: default,mms,agps,supl,fota,hipri,dun
MVNO type: GID
MVNO value: 4D4F
03-12-2020 11:06 AM
@beawolpert wrote:I set preferred network mode to "3G/2G only". Didn't change anything....
I don't know what that means what you wrote under your "edit", sorry 🙈
You have the Huawei P20. Is there any other model information you can provide? I'm wondering that your phone isn't PM LTE compatible. That would then be better with 3G.
Although I see your signal indicator in the top left that might suggest you're connecting to LTE.
03-12-2020 11:05 AM - edited 03-12-2020 11:08 AM
Set it for LTE
the phone will switch to 3g during talk
But you did be connecting to LTE
publicm mobileis on LTE they just slow it down and call it 3g which confuses lots of people, only talk uses 3g, if you don't have LTE tower around you will automatically switch to 3g
03-12-2020 11:04 AM - edited 03-12-2020 11:05 AM
03-12-2020 11:04 AM
03-12-2020 11:00 AM
03-12-2020 10:49 AM - edited 03-12-2020 10:55 AM
@beawolpert wrote:I did APN the way I was told by PM yesterday...
I'm using a Huawei P20.
WHEN it works, the connection is super fast
Perhaps you're in a weak LTE spot. Maybe there's a sweet spot to be in.
Maybe try using 3G HSDPA data rather than LTE.
Edit: what's the actual full model designation? It might not be fully compatible with PM.
03-12-2020 10:47 AM
Yes every time you do such changes reboot.
Also can you post your APN so commonty can take a look
Is there any logic in site selection, once with video or heavy Java or anything that could sort sites that do vs don't
03-12-2020 10:44 AM
That is really strange.
Do you have network reset? You can try if you do.
Also can you test your sim in another phone to see if it's phone settings or account issue.
03-12-2020 10:44 AM
Try rebooting your phone.
03-12-2020 10:42 AM
03-12-2020 10:41 AM
Please check your APN settings
Maybe do network reset if that didn't help
How is u connection?
Which phone are you using?
