Sim card malfuntion
plentz11
hi There:
the 1 month old sim card in my phone seems to be defective. phone won't operate with it inserted. it looks "warped". Can i get a free replacement? back at the place of purchase?
(it worked fine for the first month)
12 REPLIES 12
You can order a new SIM and change from within the self service account using the change sim option. You cant port between PM accounts. Stay safe.
@AmyJaneEriksen wrote:
it would take a lot of heat to do that. Check battery condition and replace as needed. you could order a new sim and new account? and port your number over to the new one.
I wouldn't use the term "port" for this as it will confuse people.
AmyJaneEriksen
LovesToPM
Hi @plentz11
It takes quite a bit of heat to warp a SIM card. You can get the SIM card replaced as suggested by others, but I suspect your phone or battery might be in need of repair or replacement.
plentz11
i will look closer tomorrow and replace it back in phone and give it another try. thanks
plentz11
great i will try these suggestions tomorrow at work. thanks!
@plentz11
That is unusual but it could happen. Try the vendor tomorrow. Not too many report on this forum about physically damaged SIM cards.
popping
@plentz11 wrote:
yes everything was great...i punch out card to fit my phone. it just quit working and actually caused the phone to not function. we removed the sim card and didn't replace it back in and the phone charges and will turn on.  the sim card looks like it is actually warped a bit as if has overheated. i will try back the vendor tomorrow to see what they say.
If that store does not give you a new one, you can get a new one for $3.33 + tax at https://canadiancellsupplies.com/collections/sim-cards/products/public-sim-card
If you live in GTA, you can pick up at MISSISSAUGA after order online.
plentz11
popping
@plentz11 wrote:
hi There:
You can try the store who sold you your SIM card.  But there is no guarantee.  YMMV.
Will it work if you take it out and insert it back to your phone?
Your SIM may move a bit in the SIM slot.
Dunkman
@plentz11
Did the Sim  card work before?  Is it the right size for your phone? If wrong size, you can punch out the correct size card.
Normally there is no free replacement. You could try the original vendor.
kselmak
Can you try your sim in different phone
And also try different sim in your phone
What happens when you insert it?
Can you maybe take a picture of that "warped" sim
Also if it is full soon or mini sim, public mobile micro SIM is nested within mini and the full size, it can get a bit detached, if that's the case you can just put done pressure on it
I'll try to take a picture and post it here
