03-03-2020 01:29 PM - edited 01-05-2022 09:45 AM
When I dial 1 to setup my voicemail on my iphone 6, I get an 'Error Performing Request / Unknown Error' screen. My wife can call my number and receive a generic Voicemail message, but I cannot check my Voicemails or set up my greeting. Any advice?
03-03-2020 09:14 PM
You can try this:
https://smallbusiness.chron.com/change-voicemail-number-iphone-56080.html
No guarantee but it worked for me so maybe its worth a shot.
This thread may also be helpful:
03-03-2020 08:58 PM
Try this:
No guarantee but it worked for me when I had this same problem. I referred to this forum post:
https://productioncommunity.publicmobile.ca/t5/Getting-Started/iPhone-Voicemail-Error/td-p/63564
Hope that helps you.
03-03-2020 07:50 PM
Try this:
03-03-2020 02:27 PM
@DFletch Try calling your number from another phone, but interupt the greeting by pressing *. That normally leads to the setup menu.
If you were tranferring a phone number, does that SIM still work?
03-03-2020 02:22 PM
I tried resetting the phone - no luck. I tried calling my own number, and I just get silence and then 'call failed'.
03-03-2020 02:20 PM
Are you a bot? The first thing I said was that I get an error when dialing 1 to initiate the Voicemail setup. I have Talk minutes included in my plan.
03-03-2020 01:37 PM
Just new? See help articles here...they are good.
03-03-2020 01:35 PM
@DFletch wrote:When I dial 1 to setup my voicemail on my iphone 6, I get an 'Error Performing Request / Unknown Error' screen. My wife can call my number and receive a generic Voicemail message, but I cannot check my Voicemails or set up my greeting. Any advice?
It is likely still setup to call the voicemail of your previous provider. Try resetting/restarting your phone.
You can dial your own number or one of the voicemail mail numbers (such as area code + "580-4001". And optionally add this number to your speed dial.
03-03-2020 01:35 PM
Set Up Voicemail
