Scam from Turkey
PSF
Stating they are public mobile +9027008594 saying that I don't have talk what's up with that
Helpershelper
@PSF
I get these calls from time to time and sometimes they guess the wrong carrier I’m with. I would just report the call using the link below.
https://antifraudcentre-centreantifraude.ca/report-signalez-eng.htm
Nothing to do with Turkey as I see it. 902 is an Area Code for Nova Scotia and 90 happens to be the Country Code for Turkey but I have to assume this is just a message from the Nova Scotia area possibly spoofing the 902 Area Code. Or is it even a valid message, what is the circumstance that you received or heard this message? A text message you received? A recording when trying to call someone? If the latter, did you try dialling 1 before the 10 digit number?
AE_Collector
Dunkman
@PSF
There are so many scams out there.  As long as your phone works fine, you should be fine.  Maybe block that number.
You might want to change the password in your self service account just to be on the safe side.  There have been several cases of SIM hijacking recently.
