01-05-2019 08:47 AM - edited 01-05-2022 02:58 AM
Hi,
I bought a BLU Advance A4 phone. It has room for 2 SIM cards. My Fido SIM card works. The Public Mobile one, I have trouble with. The phone "says" that the SIM card slot is empty, but I can send and receive text message. No calling possible, the phone says that there is no connexion.
Thanks for the help.
01-05-2019 12:59 PM
Plus, when I insert only the public mobile SIM card, no matter if it's in slot number 1 or 2, I can receive and send texts just fine.. but still, in the settings, it says that the SIM slot is empty and there is no réseau available and no calls are possible..
01-05-2019 12:23 PM
Correction: I can receive text messages sent to my public mobile phone number, but when I answer, it's automatically from my Fido number. So, even if the connexion isn't there, something's happening.. Yes, I have tried switching the SIM cards. It doesn't seem to change anything...
01-05-2019 12:17 PM
Correction: I can receive text sent to the phone number of my Public Mobile SIM card, but when I reply, its automatically from my Fido SIM card. To answer your question: my phone is new, unlocked, and I had already two plans, one with Fido and one with Public Mobile.
01-05-2019 09:51 AM
@Alex888 wrote:Is your phone still on the Fido plan? It may not have ported to PM yet.
OP did not talk about porting. I think the intent is to run to services concurrently on the dual SIM phone.
01-05-2019 09:49 AM
Try repositioning the SIM card a few times. Unless the phone sees the SIM card, there's no way to connect to the network. The sending of text may be going from the Fido service. If the Public Mobile SIM card is not recognised, there's no way possible for any activity to be originating from this service. The other possibility is the SIM card slot is bad. Try reversing the two SIM cards.
01-05-2019 09:05 AM
