03-10-2020 11:16 AM - edited 01-05-2022 09:52 AM
my card still works on my samsung s4, its not reconized on my new samsung s10e.
i did all the software updates, ive put it in a samsung s7 still no read. tried my freinds sim card and its his is a no read.
03-11-2020 02:12 AM
@SHERIFF is the phone new? Is it locked? Where did you get it from
03-11-2020 01:57 AM
@SHERIFF wrote:my card still works on my samsung s4, its not reconized on my new samsung s10e.
What's the exact on-screen message? If it says emergency calls only or no service, this could either mean that the is not compatible, the wrong network type is selected as suggested earlier, or that the phone could possibily be blacklisted for use in Canada.
03-10-2020 11:27 AM
You will need to verify each phone to see if the settings are correct. Are the other phones unlocked? Does the phones show Public Mobile and that SIM slot is active? Also check the preferred network type and set it 2g/3g perhaps.
03-10-2020 11:21 AM
This is confusing. So your SIM works in one phone (S4)? Your friends SIM works in his phone?
But neither SIM works in the S10e or S7?
Maybe check that your networks are LTE/WCDMA/UMTS/HSDPA/3G. Not GSM. Although GSM could appear in the list with the others that are needed.
03-10-2020 11:19 AM
@SHERIFF insert your SIM, try selecting PM as your network and restart your phone. Thanks.
