03-13-2020 12:16 AM - edited 01-05-2022 09:54 AM
I WANT TO USE MY EXISTING KOODOO NUMBER AND I AM SETTING UP I HAVE TAKEN A PUBLIC MOBILE NUMBER AS INSTRUCTED BUT I DON'T KNOW WHAT THE NEXT STEP IS
03-15-2020 01:40 AM
@Triguywrote:
Here is a porting guide. https://productioncommunity.publicmobile.ca/t5/Getting-Started/Start-Guide-Setup-Activation-Port-Dat...
Note that currently those instructions are not valid, as on Friday Public Mobile announced that the automated porting function in the self-serve portal is down, and requests need to be requested by contacting a mod:
03-13-2020 06:48 AM
03-13-2020 06:37 AM - edited 03-13-2020 06:39 AM
@blackbob typing in "Port request" in Simon takes you here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Send it with "Port request" in the subject line. And keep an eye on the envelope top right of your screen. The answer from the mods will show up there.
03-13-2020 01:18 AM
@blackbob, why are YOU screaming at us? Typing in 'All Caps' means you are screaming and yelling as per web etiquette! My virgin ears....owwwww
03-13-2020 01:15 AM - edited 03-13-2020 01:21 AM
Popping,
In the message on the self serve page, Public Mobile has asked customer to type in "port request" in SIMon to properly categorize and prioritize the reqeust. The good news for the customer is how all that "human" and "account specific issue" stuff will be skipped.
03-13-2020 12:20 AM
Create a moderator support ticket to port your Koodo number to PM using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
03-13-2020 12:19 AM - edited 03-13-2020 12:20 AM
So you're all set up and working with the new account?
Now you need to contact the moderators to perform the transfer/port.
Hopefully the question mark bubble appears on your screen to the lower right. Click on that and start asking and eventually it should get to a simple form to complete and follow the rest of the steps to get to them.
