Reply
eh48
Re: Transferring or Changing your Phone Number
What about if you're porting in a landline number? Those things can't receive SMS so how do I get this coveted sms authorization? I've been trying my hardest to port in a Rogers Home Phone number to PM but Telus called and said they received no authorization response from me... maybe because landlines can't receive texts? What do we do in this situation?!
Accepted Solutions
Dunkman
@eh48 wrote:
I did. Rogers says there was no port request from PM. So I contacted PM and they said they did the port correctly and that there's nothing wrong.
One of these companies is wrong. And until someone owns up, I'm stuck in limbo between 2 carriers.
@eh48
Did you contact the Telus porting team?  I will private message you the phone number (only used for porting issues).  PM/Telus likely needs to resubmit the porting request.
I will also start your own thread.
All Replies
The reply to the text message security feature only applies when porting a cellular number. The form to fill out for poring in a landline is a little different, but generally, all this is needed is for you to fill it out.
darlicious
@eh48
Try calling Rogers and verbally authorizing the port.
eh48
Dunkman
@eh48
darlicious
@eh48
Have you talked to the telus porting department yet? I can private message you the number if need be.....and rogers being well rogers could be the sticking point.
