Reply
Re: Cannot Send Text Messages
@Moderator_Team
I cannot stand text messages and renewed my plan about 4 days ago.
It keeps saying message not sent try again. They only send when i reset my phone.
@Norodaigh, what plan are you on?  When you  say it works when you reset your phone, what makes it so?
is your plan listed as active in My Account?  Do your other plan features work?
I figured it out, they wont send when I have wifi on....
Thats weird, what kind of phone do you have?
LG G5
@Moderator_Team
Never mind the messages wont send even with the Wi-Fi off!
@Norodaigh wrote:
@Moderator_Team
So is anything working, calls in/out, text in/out and data if you have it?
What does your self serve account say for status?
Is it regular text msg or picture msg. Maybe you can check your apn and mms settings. For android phones on Public Mobile they should be :
Name: Public Mobile mms only
APN: sp.mb.com
Proxy: Not set - leave blank
Port: Not set - leave blank
Username: Not set - leave blank
Password: Not set - leave blank
Server: Not set - leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: mms
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
@Norodaigh wrote:
LG G5
And what plan are you on?
If the $10 plan, even though you say you just renewed, there's still a possibility that you've used all your allotted texts.
I am on a 45 dollar plan.
I can still call and receive calls when wifi is on but not text messages.
All messaging settings are fine.
