Re: Can't Activate Sim - Stuck at Choose phone number.
phonezero
Hi - I am having the same problem. I can easily get past the first page where I enter my SIM info, however it wont allow me to select a new number. The page is stuck over there. Not sure if it is specific to my SIM. I have tried firefox, chrome and even IE.
I wanted to register to get the $40 promotion (for 4GB), which lasts only till tomorrow. Hopefully this issue is resolved before that deal is over.
Thanks all @Shazia_K@Mary_M
Mary_M
Retraité / Retired
Retraité / Retired
Hey @phonezero,
Thank you for the update ! I'm glad to hear that you were able to activate - and I also see that you successfully ported your number 🙂
Welcome to PM!!
Thank you for the suggestions @Luddite 🙂
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
phonezero
Thanks That worked!
Luddite
@phonezero The "tricks" that have helped some are:
- clear browser's cache and turn off popup/ad blocker
- don't use your phone number as the alternate
- if you are porting a number DO NOT do that during activation; select a temporary number. Transfer once you are sure your PM service is functioning properly.
- if you have long name(s) shorten them
If these do not work follow the suggestions in this post:
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
If you can't activate today with these suggestions, you should assume it will be a week before Public Mobile is functional.
Good luck.
