08-12-2020 03:57 PM - edited 01-05-2022 12:29 PM
Hi : I have switched from Rogers to public mobile on 9 august 2020 , until now I can place calls but if someone calls me my phone won’t ring and goes to my old Rogers voice mail , I called Rogers they said that public mobile didn’t ask the transfer of my phone to public mobile I don’t understand what is going on ????
08-12-2020 06:29 PM
Sometimes you have to call your old provider to get them to allow the number transfer
08-12-2020 06:26 PM
08-12-2020 04:28 PM
@Hmhajjar1 put your Rogers sim card in your phone and check for a text from Rogers asking you to confirm the port.
08-12-2020 04:04 PM
@Hmhajjar1 do as @gpixel suggests and resend your information. It appears that your request fell through the cracks. If you have problems with SiMon send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work. Type " Port Request " in the subject message field and give them the name on the account, number to port and your Rogers account number.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue.
Welcome to PM stay safe.
08-12-2020 04:01 PM
@Hmhajjar1 , did you submit a port during the activation. If not, that would explain it. Another possibility is that port protection may have intervened. It looks like pretty much all the carriers are using it now. So you are contacted by your old service provider to confirm the port. If you are not using the old service, you would not receive the notification.
08-12-2020 03:59 PM
@Hmhajjar1 hi contact customer support mods here
type "port request"
(use the chat bubble options, then click "submit a ticket, click me" option)
https://publicmobile.ca.ada.support/chat/
make sure to check your inbox(top right corner envelope icon) periodically, for a response
